Cummins12V98
Jul 09, 2016Explorer III
NC Hauler wrote:
Gotcha..Will play with height when hooking up..The rear air assist drops the bed 1-1.5".
Thanks Chris,,I thought the 17.5 was about the same size, but wasn't sure.
Jim
Just to clarify the rear drops when you place the trucks air ride system in Alt ride ht. I keep mine in alt ride height ALL the time. i like the more level look, also slightly less height to get onto the running boards.
This is a heads up for those when unhitching with rear air ride go into settings, fine suspension then select tire jack mode when unhitching. This will keep the air system from moving. Believe me it's the way to go!
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
