Cummins12V98
Jul 24, 2016Explorer III
gsbrockman wrote:NC Hauler wrote:
I can think of a 2010, 2012 and that 2013 as examples when they were traded in.
Ron...MS is setting "almost level on my Ram...pictures to follow.
Jim
Nice to have a picture posting friend. :B
Looks good, get it on some very flat ground and measure the 4 corners of the RV to the ground. Also each axle weight will tell a lot.
If you don't have the 2" riser I am sure you are nose high. Pic below does not look bad but the front was around 5" higher than the rear. I have 6 1/2" clearance at the tailgate. My axle weight was 1,400# more on the rear axle before I had the 3" riser added.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
