Chuck___'s avatar
Chuck___
2017 New truck says 5th wheel it not connect? Update 8-4-18
I have a new 2017 Ford 350 dully connected to a 2010 Dream Suite 5th wheel. When I start to pull out of my yard the truck dash reads out that the trailer is disconnected. Also when I turn the left and right turn signal on when driving the truck reads out that the signals are failed and the truck dash right or left signal flashes rapidly. I have hooked up to different trailers, have the ford dealer check the stocks, changed out the trailer 7 pin connector. I have hooked up to different trailers, have the ford dealer check the stocks, changed out the trailer 7 pin connector and check to connection on the trailer and truck to the best of my ability. Only when I connector to my DRV 5th wheel I am having a disconnected trailer reading. I am an electrician. Most RV shop that I am having a bad ground issue. Any advice please. Do I need to better ground hydrastar unit? I do have a Hydrastar electric over hydraulic actuator and disc brakes. The trailer lights are working properly and when I step on the brake the brakes do operate/ work.
I am just try to see if I over looked something before I pay a RV shop to check out the trailer and or take the truck back to the Ford dealer for the forth time.
  • If your DRV has separate turn signals and brake lamps, I would guess that is your problem. The new Super Duties somehow use the common brake lamp/turn signal circuit to sense the trailer. I ended up mounting 2 spare led lights in the battery compartment and wired them to the brake/turn circuit before it is split. Solved all problems including the truck's charge circuit not energizing.
  • If the Ford works fine with other trailers, it would not be high on my list to be the problem. A 2010 is few years old. I would check the umbilical cord and its connections on the trailer. A wire could have gone bad inside the cord or a connection to the trailer bad giving intermittent operation.
  • might try some dialectric grease I had the same issue with my gmc and this solved the issue
    Do you have the brake controler set to electric over hydraulic?. I found that setting by accident.
  • F-TROUP wrote:
    My son's GMC Dinalli showed the same message, it was a loose ground wire in his 5th wheel cord.
    Ditto I had to replace the plug on mine, not hard to do.
  • My son's GMC Dinalli showed the same message, it was a loose ground wire in his 5th wheel cord.
