Mike_LA
Nov 08, 2017Explorer
deereequipment wrote:Your RV will have a CABLE INPUT jack on the street-side(left side). This is where you will connect the campground Cable Input. It may look like one of these below.
Mine toyhauler has 3 coaxial ends (jack?) where I would hook up the cable tv from the campground.
I have 3 tvs inside, and there is a jack in the storage area for an outside tv.
I thought maybe a jack for each tv inside, but then there's the outside jack.
Do all 3 of the hook ups need to be attached to the cable supply?
Like should I tie all 3 together so the one cable from the campground will run all my tvs?
If it's just one of the 3 jacks that I need to hook to, which one?? (Mine aren't labeled).
Thanks.
One TV location will have a wall plate that looks like this. It may be White or Black.
TV Jack Connection PDF
About Fifth Wheel Group
19,025 PostsLatest Activity: Nov 02, 2015
