g00fy's avatar
g00fy
2018 Grey Wolf 27RR Corner Molding Issue
My Grey Wolf 27RR is having a problem where the rear corner molding and siding on both sides is pulling away from the rear frame it's screwed into. It's not just the silicone that's pulled away, I can see the mounting screws inside have snapped as well. I assume this is from the frame flexing during trips, but i'm concerned this is going to be a major issue if it's snapping the screws. I've only taken the trailer on about 6 trips.
I noticed the issue last year, but it was so minor I let it go. Unfortunately as you can see from the pictures it's gotten worse, I circled the broken screw in the one picture it can be seen in. I'm out of warranty, so I don't know if i just fix this by putting more screws in and resealing, or if those screws will end up breaking also.
