time2roll
Jan 30, 2017Nomad
4000 is the listed minimum for a single air. Two would be marginal if they even start. But the new A/Cs are getting better so maybe a longshot but not impossible. Maybe 2x 13.5 high efficiency units. Or a 13.5 and smaller 9 or 11k BTU. Good luck.
If the RV is well insulated, parked in the shade, and you have a superior installation the single air should be fine. Reality is not likely as temps go 95+ if you want a steady 72 inside.
About Fifth Wheel Group
19,034 PostsLatest Activity: Mar 15, 2026
