xanth
May 28, 2019Explorer
Roger10378 wrote:
There are several videos on u-tube showing the sealing of the air passages to correct the problem. I would start there. If there is air leakage between the cold air and the return you will get those exact symptoms.
Thanks. Good advice. Just went through you tube and took the interior panel off and took a look inside to make sure there were no big leaks from he release side to the input side. Looked pretty solid.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
