GHop
May 31, 2019Explorer
xanth wrote:
We installed a 2nd AC in our 30ft Fifth Wheel a couple months ago. Decided to go with the Penguin II low Profile 13.5 BTU over the bedroom area.
Everything seems to work, it powers on and you can tell a difference when the compressor kicks on, but it just doesn't seem to get as cold in the bedroom area as I expected. Now I haven't had it on that much (we haven't taken any trips in it yet), but overall, i'm underwhelmed by its performance. I've only run it off the household current (20V).
We have a 15K BTU AC as the main AC unit, and I can leave it on all day and the trailer will get chilly inside, but the bedroom one just tends to get somewhat cooler.
I've done a bit of research, and some people say the 2nd AC makes the bedroom area an ice box when it is left on. Of course, others say it just cools it down.
What makes me really wonder, is I had left the 2nd AC on all night (on high) the other night (forgot it was on) and when I went into the trailer the next morning, it didn't seem cool at all. Figured it might have froze over the night, so I let it sit all day and turned it on the next day. Same results, I can tell the air is cooler (coming out of the AC unit), but it is not as cold as I was expecting.
Before I call Dometic to see what they say, or if they might warranty it, does anyone have any first hand experience?
Are my expectations too high? It cools the bedroom a few degrees, but doesn't make it cold.
Some of my research tells of a Dometic trouble shooting guide for the AC units, but my google-fu is failing me, and I can't find it.
Thanks for the help!
They are correct, your AC should freeze you out. I would give Dometic a call after checking the setting.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
