Jerry_L's avatar
Jerry_L
30 15 amp circuit breaker
I have a 5th wheel and found to have a weak 30 15 amp twin pole circuit breaker. This breaker is the main breaker (5th wheel is 30 amp) and the 15 amp is for the water heater. I've temporarily replaced the 30 15 amp with a 30 amp, connecting the water heater to it. Upon returning home, I have been trying to locate another 30 15 twin pole circuit breaker with no success. I've called most if not all the electrical supply companies who keep referring me to other companies that I have already contacted. Apparently, no one carries a 30 15 amp twin pole circuit breaker. I've reluctantly contacted an RV dealership asking if they carry the circuit breaker. I was informed it is no longer manufactured. When asked how they would repair such a problem, they indicated the installation of two separate breakers, one 30 amp and the other 15 amp. Question for members of rv.net, should I quit looking for the 30 15 amp and install two circuit breakers? Will there be problems with the 5th wheel if I leave it as?
  • BTPO1 wrote:
    X2, it is a 30-15 breaker for a reason. JMO
    OK so there are at least a couple of supposed electrical experts who frequent here and..........
    What possible electrical reason could there be for having the main breaker (30 amp) ganged to the water heater breaker (15 amp) ??
    This makes no sense to me and I see absolutely nothing wrong with putting in two individual breakers of the proper size.
  • If you have an available slot in your breaker panel it would probably be far easier, cheaper, and quicker to use separate breakers instead of the weird 30/15 tandem.
    If you have to use the tandem then the Siemens should fit. Just about any RV panel I've seen uses breakers that are physically compatible with Siemens breakers. For the record the following breakers are all physically interchangeable: Siemens, Westinghouse, Murray, Cuttler Hammer BR series, Square D Homeline series, GE, and ITE.
    If this were a job getting inspected then there may be a problem mixing brands if you had a really picky inspector. Since I'm sure that's not the case you will be fine.
    Do not leave the WH connected to the 30 amp breaker. That breaker, being the main, is actually fed at the terminal so your WH wire is live all the way from the plug. In other words, there's no way to turn off that circuit except to unplug the RV. If you ever use an adapter to connect your 30A service to a 50A outlet then the 50A breaker in the pedestal is all that is "protecting" the wire to the WH. Not a good situation.
  • BB_TX wrote:
    Not all manufacturers breakers are interchangeable. Get the manufacturer model number off the breaker and then google it. I had the same problem finding a 20/15 breaker. Googled the model number and found numerous sources. Bought one on line, delivered in a couple days, and installed it.
    And no, do not leave the water heater on a 30 amp breaker. The wire is not likely sized for that current. A short could cause a fire.
  • Buy a 30A single for Main and a 15A single for water heater.
    Just need to match up style with what is in your breaker box
  • Not all manufacturers breakers are interchangeable. Get the manufacturer model number off the breaker and then google it. I had the same problem finding a 20/15 breaker. Googled the model number and found numerous sources. Bought one on line, delivered in a couple days, and installed it.
  • gbopp wrote:
    Will the Siemens breaker work in the OP's breaker box? Are the breakers universal,?
    I don't know. If you look below where they show similar products there is a Murray brand (which I've never heard of) 30/15.
  • Will the Siemens breaker work in the OP's breaker box? Are the breakers universal,?
  • Siemans must not have received the news that they weren't being made anymore:
    Amazon
    It's rare when you can't find something on Amazon.
