ScottG wrote:
Assuming replacing the wiring isn't too hard, your really safer just having a 50A outlet supplied because that is a standard range receptacle and electricians are more familiar with them. Then you can use an adapter for 30A or if you have a 50A rig (I'm not clear which you have) you can plug directly into it and have much more power available.
A little clarification is needed here. Older three prong appliance recepticle ARE NOT compatible with RVs and the existing wireing does not have a neutral, which is necessary for an RV.
