mjvedo's avatar
mjvedo
30 amp adapter- newbie here
Hi All;
Just picked up a fiver and planning a shakedown stay in the driveway. Our first trip will be to our property that has an unlivable house. It has a conveniently located dryer outlet. Is there an adapter offered that will adapt my 30 amp shore cord to the dryer outlet? Or do I need to make one up, or is this not recommended?
MJ
  • NO! no adapter. This is one of the most common scenario's we read about on here. Ultimately the poster comes here with stories of smoke and failures of every electronic item in the RV.
  • 30A dryer oulet
    2 hot legs (110V on each leg)
    1 ground eg
    30A RV
    1 hot (110V)
    1 ground
    1 neutral
    Plug 30A RV into 30A dryer outlet and you will fry the ac appliances and probably converter because of the 220V AC power.
    NO NO NO
  • mjvedo wrote:
    Hi All;
    MJ
    I thought you were joking, but maybe not. It is not recommended.
    Jerry
  • mjvedo wrote:
    Hi All;
    MJ
    For Heaven's sake do NOT do that. Just because the dryer outlet appears similar to an RV 30A outlet does not make it so. The dryer outlet is a household 240VAC outlet. A similar looking RV 30A socket is 120VAC. If you tried plugging your RV into that house dryer outlet you would cause serious damage to your RV.
  • Dryer outlet is 220VAC. Your 30 amp RV is 110VAC. If you have to ask, you don't know enough to mess with it. Get an adapter to plug your 30amp into a 15/20 amp wall outlet.
About Fifth Wheel Group
19,025 PostsLatest Activity: Nov 02, 2015
