DutchmenSport
Feb 16, 2014Explorer
I don't think it matters which color you use as long you own your house and you never want to change anything. However, if you ever decide to sell the house that wiring configuration will most likely fail an inspection (but it will not hurt anything or cause any problems ... just inspectors). If you ever decide to sell, just unhook that wire and put it back the way it was.
When we had our garage wired for 30 amp, I had an electrician actually hook the wires into the breaker panel and the outside plug box. He said, Black wire to the copper colored screw, white wire to the silver colored screw, and the third one to ground.
About Fifth Wheel Group
