Bigmoss's avatar
Bigmoss
30 Amp Service ?
I am planning on putting a 30amp RV panel on the outside of my garage which has its own meter fuse box. What's involved for having an electrician put a 30amp service in for my 5er so I can run the ac and stuff is it just a matter of adding a fuse to the panel and the proper wire from the panel to the box on the outside ?
  • That's it. Most important part is to shut off the main breaker before you start!!!! Fron there, it is very simple to add a new circuit to an electrical box. You just have to remove the cover, snap out a tab, run your wires, snap in a new circuit breaker and re-install the cover. Minimum 10 guage wire is necessary.
