kopy_kat's avatar
kopy_kat
30 amp vs. 50 amp question
I have a spot reserved at an Rv park, but all they had available was a 30 amp hookup.
So...
-do I still put my 50 amp EMS In line after the 30/50 converter?
-I know I can’t run both a/c units, but can I still run the heat pump?
So much to learn with this new unit!
Thanks, Larry
  • EMS and heat pump OK, you just can't exceed the 30A pedestal CB limit with all of your loads.
  • Yes.
    Shore power-->adapter-->ems-->rv
    Limit your loads to 24 amps if that is possible.
    If you are lucky enough to have a hybrid inverter/charger, then turn on the load support feature.
