- pianotunaNomad IIII would go with an autoformer, which includes surge instead of just a surge device. Low voltage kills far more than high voltage surge.
- fj12ryderExplorer IIIYou can always use a 50 amp EMS with 30 amp service, but you can't go the other way. I'd get a 50 amp EMS and call it good. I had 2 SurgeGuard and had both of them fail due to water intrusion. The new ones look different and may work better but I wouldn't trust them. I'd go with the EMS-PT50X.
- RockyMtExplorer III have a 50amp trailer and a 50 amp protector, when plugged into 30amp I get a fault.
It still works however(the power). Just has a fault light. - Ed9824vExplorerIs your rv 50amp get 50amp will work with 30 AMP campground service
If you're rv is 30 AMP get that - StirCrazyModeratorif your rv is set up for 50 amp power get a 50 amp surge protector. if you ue a portable one like me, just plug your surge protector into your 30 amp adapter cable.
Steve
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
