coolmom42
Dec 21, 2016Explorer II
Check all your connections etc. Make sure everything is tight.
And cut back your power consumption. If you need the amount of heat from 2 electric heaters, you will have to use propane in place of one of them. But I can't fathom why you would need that much heat unless someone is living in the RV.
Aside from the heaters, your converter may be a heavy draw if your batteries are down.
About Fifth Wheel Group
