time2roll
Dec 21, 2016Nomad
driller wrote:Often it is the weak crimp connection on a moulded adapter.
The receptacle is fine it's only at the adapter on the 30 amp plug side! All the signs point to pulling to much power.
You could try this premium replacement plug from progressive industries.
http://www.progressiveindustries.net/tt-30p-connector
Of course best would be to upgrade service. If you can pull just one #10 wire and pop in a double 30a breaker you could double your power and use a 14-30 outlet.
About Fifth Wheel Group
