RVcrazy wrote:
What can you do without trouble with only a 30 amp connection? Run a Splendide washer/dryer? If you have a 15000BTU a/c unit, can you use it at all with a 30 amp connection? Other considerations?
...........If , you want to get maximum usage out of a 30 amp plug , use a 50 amp power cord with a short adapter on each end of the 50 amp cord . This way you have virtually , NO voltage drop from the outside plug to the connection on your RV .
...........Voltage and amperage move in Opposite directions , i.e. , IF you use a regular 30 amp RV extension cord , the voltage will start dropping under heavy usage , which makes the amperage climb , your plugs get VERY hot and cause more problems , thus popping the 30 amp breaker ! , jf
