JIMNLIN
Jan 20, 2017Explorer III
op wrote:
From what I have been studying the Ford and Dodge gassers have better payload and the diesel has more towing capacity.
Ford/Ram and GM 3/4 ton trucks have similar 6000-6500 RAWR that will carry all the weight in the bed of a pickup truck so actual payloads in the bed differ very little.
Gas trucks rear axle can weigh about the same as a diesel trucks rear axle as the diesel engine adds very little weight on the rear axle.
Payloads your talking about is a gvwr based payload located on the tire placard. A gvwr payload may need to be spread over the trucks gawrs (front and rear axle).
Example ....one of our members said his 2500 GM 6.0 gasser had a 3640 lb payload sticker. There is no 2500 GM gas or diesel truck that can carry 3640 lbs in the bed without exceeding a 17" OEM tire/OEM wheel or OEM rear spring pack rating.
2500 GM trucks have a 6200 rawr and most newer gen truck can weigh in the 2900-3100 lb range leaving 3100-3300 lb for a max load in the bed.
My point is don't assume all the gvwr based payload numbers can safely be carried in some (not all) trucks bed.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
