rhagfo
Feb 05, 2014Explorer III
socoguy wrote:dennych1 wrote:
I am thinking of
going from a 34.8 ft Everest which is 11.5k loaded to a Big Horn 3160 35.6 ft which will be 13.5 loaded. I know I will be over pin weight around 500lbs . The combined weight is within specs of truck. Just wanted to see if anyone else is carrying this weight on 2500HD diesel and how has it been.
Thanks Dennis
Would never be worth the peace of mind. Truck will do it but it would be overloaded and put you at risk. Insurance could be a definate issue if you have a mishap. Over on pin weright will stress rear axel and tires. TGhere is so much info here to the contrary. Reconsider the trailer or the truck. Good Luck
Really!
I think it is pretty well established that most 2500/250's are nothing more than 3500/350's SRW, with softer springs. That may have changed for some in 2013, but before that pretty much spring stiffness.
That and many 2500/250's with Camper packages have 3500/350 springs, just missing the badge.
About Fifth Wheel Group
19,033 PostsLatest Activity: Mar 03, 2021
