Atom Ant wrote:
If you can find one you like, you're steps ahead with the 1-ton. Its the difference between a 6,000 lbs rear axles rating on a 3/4 or a 7,000 lbs rating on a 1-ton. T
Rating is the key word.. and it's a rating that is not always based on ability.
If are shopping for a truck I agree completely, but if you own a truck then it's not that much different.
I am a Dodge guy so I this may not be 100%, but I do believe that GM uses the same axle on all 8.1L/Diesels 3/4, 1 Ton, DRW the AAM 11.5 and the 14 bolt on the 3/4 6.0 truck. This is the same axle that Dodge uses on all Diesels 3/4 or 1 Ton SRW/DRW, an axle that AAM rates at 10,900lbs SRW or DRW. That's higher than either GM or Dodge give for a RAWR, so the axle is strong enough.
The 2500 Hemi axle has a 9,000lb rating and the 2500 6.0L has a 8,600lb rating if you own a 3/4 gas rig. No clue on what Ford uses for 3/4 gas.
Ford does use a different DRW axle (D80) than SRW (Sterling 10.5"). The D80 is 11,000 and the Sterling is 9,750.. all above RAWR of SRW or DRW.
Okay, so those are the axle numbers and the lower RAWR limits are in part due to badgeing (3/4 vs 1), tires, suspension, etc...
That's where it get's trikcy and more vehicle specific, so here is what I know about Dodge.
Same frame 2500 Hemi or 3500 DRW CTD (assuming same cab/bed config) from 03-12. 13 had different frames but 14 is back to the same frame.
Front axle and suspension is the same 2500 to DRW, brakes are the same. The only difference from 03-12 was the rear suspension. In 03-09 if the truck was SRW it had the same main leaf spring pack for the rear. The 3500 SRW got the overloads that don't contact until you are at 95-98% of tire limit, pretty useless (and my guess as to why they where dropped in '10). 10-12 3/4 and 1 Ton SRW's had different main leaf packs, the SRW 1 Ton got the DRW main pack without the overloads. The DRW main pack is only rated at 7% more weight than the SRW main pack, minimal.
I have friends that know those same specs for Ford and GM, IIRC the biggest difference on a Ford 250 to SRW 350 was the rear spring and block, the important stuff like frame and brakes where the same. I say important because airbags are easier to install than brakes/frame.. and are useful on most loads anyhow. .
So back to what I said about shopping vs own, if you are shopping go for what you need but if you own then realize what is the same and see where you need to go.
In either case (unless you have one of the newer trucks with 18's) you are probably going to run out of tire capacity first.
GVWR is a paper rating for the most part. My truck has a 9,900 lb rating, several years later it upped to 10,100 with no hardware changes and the same frame gets a 12,200 rating with a DRW.
On a SRW RAWR is based on tires, and at least on Dodge the 2500 is lower than the 3500 because it's a 2500 and there "needs" to be a difference in a 2500 and 3500.. just like a 2500 has a 900lb lower GVWR than a 3500 SRW with everything identical but the overload pack (the one that isn't used within tire limits).
Just be educated, don't assume a SRW3500 is safer than a 2500 because in most cases they use the exact same setup and the biggest difference is the piece of paper (that really has no legal bearing).
Don't exceed tire limits first and foremost. If your truck has 17's you got the short end of the stick, nearly all 16's and 18's in comparable sizes have a higher load carrying capacity.
If your going to ditch the 17's for a bigger wheel for load rating I suggest the 19.5" route.
Alright, rant off... just educate yourself and don't make blind decisions.
