94-D2
Feb 14, 2022Explorer
Moving down the highway, length is not a problem. The challenge is fueling (have to stick to truck stops or a very open stations), entrance roads to rv parks and maneuvering within the rv park. My rig is 42’ and pulling with a SRW CC short box Ram 3500. So I have a decent radius. My problem is I have nearly 16” of rear overhang. Tail swing on my rig is horrendous, as is many of the larger rigs in this size range. Even though I realize it is present, it has still bitten me in the @ss three times now.
So, look for the shortest rear over hang as possible no matter how long you are. If I could do it over again, I would look in the 10-12 overhang area. Even a 53’ box van big rig only has about 10’ of overhang with about a 72’ overall length. King pin to rear axle length is also a consideration. The longer that measurement is, the more room you need to turn that combo.
Larger rigs are challenging to say the least, and some rv parks are a bit unforgiving. I drive a 63’ transfer truck for a living and don’t have as much trouble with it as I do my 57’ of rv and truck.
Good luck on your quest. And safe travels.
About Fifth Wheel Group
