theoldwizard1's avatar
theoldwizard1
Explorer II
Dec 22, 2017
Different TT construction
It seems that the industry is slowly moving away from wood stud, fiberglass insulation and aluminum siding to the fiberglass skin, aluminum tubing, solid foam for wall construction. Both have their pluses and minus and fans and critics My question is, Is there any weight/cost savings between these 2 methods ?
Second, is flooring. Several companies have tried composite flooring. Most (all?) have switched back to the tried and true 3/4" plywood. My assessment of the failure of composite flooring is that there was not enough aluminum tubing used in the floor PLUS the same fiberglass panels used for wall construction were used for the floor. My research has shown that no fiberglass skin manufacturer recommends their product to be used as a subfloor. Has this changed ?
