JBarca
Dec 27, 2017Nomad II
Durb wrote:
I replaced most of the screws (over 600) on my trailer with stainless steel and they were only $3.50 per box of 100. A dab of silicone under each screw head. I think the manufacturers use hardened self drilling TEK screws to speed up installation. These are plated and start to corrode immediately when wet and in contact with aluminum. I don't know if stainless would work well as a self drilling screw.
I have gone to the stainless too. I did get some self drillers where I needed that feature. They work well through aluminum and steel sheet metal.
These. https://www.albanycountyfasteners.com/Self-Drilling-Screws-s/1618.htm
They are made from 410 stainless which is harder than 304 stainless that I use all over where non self drilling is needed.
And yes, the original steel ones are hardened. They are hard as heck to cut off, or even drill out. They will chip off a cobalt bit even in short order. But they do grind off if the area allows it. Once the head rusts out, that nub can be a bear to get out.
44,070 PostsLatest Activity: Sep 18, 2026
