Veebyes
Feb 15, 2022Explorer II
The bigger you go all you are getting is more floor space & more storage space. The furniture is the same size. The stove is the same size. The fridge is the same size. The only thing bigger is likely to be the TV.
As pointed out the biggest loss with size is CG options. Once you get past the mid thirties in length your availability in nice SPs, CPs etc. is drastically reduced leaving little choice but the private CGs all jammed together.
Choices & compromises.
About Fifth Wheel Group
