Bumpyroad
Dec 08, 2014Explorer
outnabout wrote:
You may want to read this. It's one of those "just because you can, don't mean you should
http://rvservices.koa.com/rvinformation/rvmaintenance/rv-electrical-101.asp
that article meandered off into the rare air area a bit. said if you hook a 50 amp RV to a 30 amp outlet that you were excessively affecting the campgrounds electric service. As far as I can tell, if you plug your 50 amp rv into a 30 amp outlet, you are "abusing" the campground's electrical service exactly the same as if you had a 30 amp RV. Can't be drawing more than 30 amps.
I think I would find some other "expert" to consult with.
bumpy
About Fifth Wheel Group
