tinner12002
Dec 13, 2014Explorer
I've been in that situation where I needed 50amps and only had 30amp available, if there is a 110volt plug in next or near to the 30amp, they make an adapter that you can plug into the 110volt receptacle and the 30amp receptacle and then plug in your 50amp, that would give you around 45amps available.
About Fifth Wheel Group
