Bumpyroad
Dec 13, 2014Explorer
tinner12002 wrote:
I've been in that situation where I needed 50amps and only had 30amp available, if there is a 110volt plug in next or near to the 30amp, they make an adapter that you can plug into the 110volt receptacle and the 30amp receptacle and then plug in your 50amp, that would give you around 45amps available.
I believe that what you are talking about will not work with GFI outlets.
bumpy
About Fifth Wheel Group
