TT_Tim
Dec 14, 2014Explorer
If you do a search, there are LOTS of places you can purchase this adapter. I have seen approval on a lot worse designs (such as press on wire connectors). The concept of the Camco Power Maximizer is good and I don't see a problem with it. As long as the electrical wiring to and at the pedestal is to code, it shouldn't be an issue.
As stated before, the problem is when someone tries to turn on too many items at once and they continually go out and reset the circuit breaker. That can happen no matter what plug and/or adapters for whatever size RV it is.
About Fifth Wheel Group
