Coach-man
Dec 22, 2013Explorer
Two AC units = 50 Amp service! If your rig is large enough for 2 AC units then in the summer when it is hot you will want them and the 50 amp service. But if one AC unit will do the job, IMHO 30 amp will be a better bargain! Some rv parks upcharge if you require 50 amp service, some older parks may have only 30 amp sites or limited 50 amp sites, and when traveling you have to always ask! If you are 30 amp and for some reason only have a 50 amp outlet a simple adaptor is all you need. But the other way 50 amp and only a 30 amp plug, then it is more complicated and expensive, and if both outlets are on the same phase your $500 device will not work!
About Fifth Wheel Group
