The pastor at the church I attend purchased an older TT and had a professional electrician wire the 30 AMP RV receptacle. You guessed it - he wired it for 240 Volts. Pastor plugged in and blew the new TV, new microwave, and the new rooftop AC would not work.
He then called an amateur RV electrician (me)to show/tell him what went wrong and correct the problem.
I pulled out the dual pole breaker and replaced with a single pole 30 AMP breaker and rewired the outlet. Tested all the outlets, etc. and all were good. A/C still would not work. I pulled the cover off the junction box, and the RV shop that did the A/C install did not connect the wires in the junction box. Saved the A/C.
Pastor replaced the TV and Microwave and used the TT for 8 years. I purchased the TT from him and restored the interior and donated the TT to a church camp in Missouri. The director of the church camp's Grandfather was the original owner of the 1985 TT. The A/C still works today!
I wired 50 AMP and 30 AMP RV outlets at the church camp where the new TT has a home.
