Bigmoss's avatar
Bigmoss
50 Foot 30amp cords ?
I park my 5er near my garage in a certain spot as its the only one that it fits in. I am going to have an electrician come and put a 30amp fuse in my panel and an outside box/plug in the corner of the garage closest to the trailer. Im not quite sure if a 50ft ext will make it so I was wondering if any members have every chained 2 50 ft extensions together and did it work ?
I know the general rule of thumb is the longer the cord power lost I just want to make sure the AC will still run with a cord that long.
Thanks
  • I have my mh plugged into an outside receptacle using the standard cord plus two 25' extensions. Works fine.
  • Yep, I've done it before and was still able to run my AC with no apparent current issues. Would it be better to run an underground feed with a riser and box near the RV so you don't have to use extension cords?
