The rig is designed to use more power. Multiple A/Cs, HW, MW, etc and you may want to push that additional button but can't - The 30A pedestal CB will trip.
I added an additional circuit with 2 plugs mostly for ceramic heaters. For 50A pedestal it plugs into an existing basement outlet. For 30A I run an extension cord to the pedestal (most have 30A and 20A outlets). Others have modified a AC power wires so it can be run off of the extension cord. By all means use a heavy extension cord and not the typical home cord.
If you are not aware 50A is 240/120V 4 wire. In RV speak this simply means you have two 50A 120V circuits for the rig or as some like to say 100A available vs the 30A  pedestal.
