nole_trainer's avatar
nole_trainer
50amp on RV, how to plug in at home?
I have a 50amp Wildcat, just pulled into driveway for first time. Was going to sleep in tonight with boys, but the AC keeps breaking the house breaker. I have the 50amp plugged into 3 prong dog bone, do I need to step it down to a 30amp dog bone first, then plug the 30amp into the 3 prong house plug dog bone?
I realize I can only run one AC (have two), but just have some lights and tv on and the circuit pops?
I will not store at house, so this is just a every-know and then kind of thing. Not sure I can justify installing a 50amp service?
  • garysol wrote:
    is this what your 50a to 3 prong plug looks like?
    Yes, pretty close
    http://www.amazon.com/gp/product/B00HRHWHNW/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
  • garysol wrote:
    If you have a 50amp to 3 prong adapter that should be all that you need to plug into your 20a home electrical. If your extension cord is this or very long that could be causing issues. With the A/C off can you run your TV? Since you have 2 A/C units I assume one may be a smaller unit. Have you tried to fire up the small one only?
    AC off, everything runs fine. I think garage circuit I'm on is not 20amp, that is probably the prob. Thanks! To top this off, my home AC is not working when we got to the house, so I thought "No problem, will sleep in RV with the boys". ugghh!
  • If you have a 50amp to 3 prong adapter that should be all that you need to plug into your 20a home electrical. If your extension cord is this or very long that could be causing issues. With the A/C off can you run your TV? Since you have 2 A/C units I assume one may be a smaller unit. Have you tried to fire up the small one only?
  • garysol wrote:
    Your 50amp is plugged into a 3 prong dog bone? How did you do this without plugging into a 50 to 30 amp adapter plug first? I am afraid I may know the answer or maybe I am just picturing what you have done incorrectly
    I have a 50amp to 3 prong dog bone. Then the 3 prong end into a heavy duty extension cord. I have a 50amp to 30amp dog bone, do I need to plug that in first, then plug the 30amp into another dog bone (which I do not have, yet)?
  • Your 50amp is plugged into a 3 prong dog bone? How did you do this without plugging into a 50 to 30 amp adapter plug first? I am afraid I may know the answer or maybe I am just picturing what you have done incorrectly
