golf_bears wrote:
OK, if I understand correctly, pin box as low as it will go and hitch as high as it will go. Truck rides level but RV nose rides low.
So your only choice is to raise the RV by adjusting the axles. This is the point you are at now.
What brand torsion axles is on your RV?
The front axle is already lowered. They I believe are Dexter. I would have to raise the axle so there is not as much pressure on the front tires. The front axle is already lowered to the bottom of that slot leaving a 1 inch gap between the frame and the axle mounting flange. I would close that gap like the rear axle, flange to frame tight. ???
