Old-Biscuit wrote:
If you 5th wheel is swaying while in tow it has nothing to do with location of axles.
Your problem sounds like truck/trailer not properly matched.
Trailer towing nose high, not enough pin weight, under-inflated tires, broken spring/hanger/bushings....
What are your weight numbers?
Does trailer sit level when hooked up?
What pressures in tires?
Have you inspected suspension components?
What speed are you towing at?
5'vrs rarely have sway issues
My 5er does!
I need more pin weight I know!
I can't move weight forward, because I already have. I can feel a difference moving 15 gallons of fuel from the back to the front of the 5er.
