fly-boy wrote:
How high is your truck? Is it lifted up real high? Are your running E rated tires on the truck?
I would still go with moving or adding fresh water tank(s). Far easier than moving axles and planned correctly you end up with extra water capacity. Also- if you can get the trailer to pull nicely with five quads you don't need to move much weight forward to get this sorted.
Stock height truck, e rated tires all around, no way to move or add water tanks, plus that is a band aid, and would change during a camping trip. With 5 quads, I had 3 in front of the axle that is a big difference.
