rhagfo
May 24, 2016Explorer III
TNrob wrote:rhagfo wrote:goducks10 wrote:
I tow and have been for 3+ years a 9000lb 5th wheel that weighs (Oregon Scales) 9000lbs loaded with an 1800lb pin, with a 2012 Ram 2500 CTD. Tows like an absolute dream. My GVWR is 9600lbs, I'm at 9800lbs. I've added 18" tires with a 6830lb rating on the rear. I'm under GCVWR, tow rating and RAWR even with the OEM 17" tires. Rear axle weight with 5th hitched is 4900lbs+/-.
I wouldn't even think twice about hitching a 9500lb 5er up to your truck.
X2!
Let me add that your 2016 Ram 2500, 6.4 hemi scales less than my 2001 2500 CDT. I carry/pull a 12,360# GVWR 5er with about 2,200# of pin (loaded at just over 11,000#), and the TV scales right at 10,000# loaded, with a 19,500# GCVW.
That's what I'm expecting to see. All of the 5ers I've looked at have way more cargo capacity than she and I will ever use before this truck is worn out. I know I'll have another one day, and if we're beginning to push capacity I'll get a 1 ton. Really I see trailers with 4-5000 pounds of ccc, and I know we won't get there running long weekends 3 times per year. I'm being conservative when I get 9500 or so because I could sometimes have my truck cab full of towing capacity and if I plan for a 10.5k trailer I might wind up bumping ugly with a weight rating. If I start at 9500 loaded, guess at a reasonable load, back up from there to a dry weight... I should wind up good at the scales with room to spare on all weights.
Well our "dry" weight is listed as 9,820# and a GVWR of 12,360# giving us a 2,540 payload on the 5er, we are loaded to about 11,000#+, so we seem to be carrying just under 1,200# of stuff. I think I need to weigh again as i travel with the fresh water tank full all the time.
About Fifth Wheel Group
