cummins2014
Dec 10, 2019Explorer
DesertDogs wrote:
SO, with the Anderson rail mount, you can set the mount to some determined (but adjustable) distance back from the truck rear window, which pretty much ensures that the front cap won't hit the rear window in tight turns?
Is it light weight enough that someone who isn't "superman" can remove it from the truck, and re-install without requiring help?
Yes, easily removed with one person , pull four pins and lift out.
The rail mount can be installed in two different positions , as well as the adapter , so basIcally four different adjustments . I run the adapter and hitch in the positions that allow the fifth wheel furthest from the cab. As far as hitting the cab on my Megacab , have never come close , I have no idea what degree I can back , but I haven’t been in a position that was a problem .
About Fifth Wheel Group
19,043 PostsLatest Activity: Aug 23, 2026
