Me_Again
Dec 13, 2019Explorer III
DesertDogs wrote:
End cap on the Solitude
Likely pin box that will be on the 2020
Does either the front cap or the pin box look likely to present a problem to either the rear window, or to the side rails of the truck in tight turns?
Couple things to remember:
One, the RAM short box is the shortest of the three.
Two, going forward is not a problem, as the truck will not turn tight enough for the trailer to contact the cab. It is backing up where the issue occurs. With a mega cab, the contact will be even farther away from the drivers seat and hard yet to monitor for contact issues.
In the fall of 2015 when we purchased our RAM, I knew I wanted the pucks and installed them myself, as the truck we purchased off the lot had everything else we wanted.
At the time there was not a slider, manual or auto that mounted via the pucks. There is now B&W Slider So I choose the Demco picture frame and the B&W manual slider. Because of the position of the B&W latch handle and the front bed box I had, I had to slide the hitch to uncouple. So I became SOP to slide the hitch back at check in and forward after straighten out of the street to exit a park or campground. So I never had an issue. With an auto slider I would have had a problem releasing the trailer as the handle would not clear the front box.
I used a HF hoist to lift the hitch and picture frame in and out of the truck as a single unit. I ran without the trail gate as I had a V-Box behind the hitch. I modified the front box twice. This box had been in my 1993 and 2001.5 RAMs. The first mod was step in the rear low side to clear the Demco picture frame and when we bought the Big Horn, I had to shorted the box from to back to clear the bigger pin box.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
