cummins2014
Dec 13, 2019Explorer
Durb wrote:
Don't pay extra for the RotoFlex pin box because you will have to lock out its function when using with an Andersen hitch. If you want the chucking control of that pin box, you will have to use it with a conventional hitch.
In my post regarding the broken rear window, the man's trailer was similar to yours in that the front cap tapered forward. His situation involved a tight backing scenario combined with a driveway. When the truck tires hit the driveway dip, the trailer leaned forward, busted the window, and dented the cab near the roof. Not a typical scenario, but many of us have backed tight on uneven terrain. I did witness the bites his pin box took out of the inside of his tailgate. His truck was a beautiful high end model (Platinum if I recall). He was not happy at all.
So, with the adapter in one position, his pin box was impacting his truck. Switch the adapter and out goes the window.
After reading your post again, I don't believe thats TRUE as far as not using that Rotoflex with the Andersen, unless there is some reason the adapter cannot fit on the pin box. Looking at it ,I can't see where thats an issue. The Andersen is not a gooseneck hitch . If I remember there was the same said about the MorRyde. IMO you are confusing what they say, not to use with a gooseneck hitch. The Andersen is no more a gooseneck then my Reese hitch. Connecting the Andersen with a ball to the adapter changes nothing as far how the MorRyde functions, which is fore ,and aft movement . Is that not the same function of the Rotoflex, and if not, it still would not make any difference. I can see a problem with the gooseneck arm trying to flex back, and forth being extend down to the bed.
Unless I am missing something , that Andersen does not change anything other instead of sliding into a conventional hitch ,and connected ,its connected with a ball. As said its NOT a gooseneck, there is a lot of difference.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
