Durb
Dec 13, 2019Explorer
cummins2014 wrote:
After reading your post again, I don't believe thats TRUE as far as not using that Rotoflex with the Andersen, unless there is some reason the adapter cannot fit on the pin box. Looking at it ,I can't see where thats an issue. The Andersen is not a gooseneck hitch . If I remember there was the same said about the MorRyde. IMO you are confusing what they say, not to use with a gooseneck hitch. The Andersen is no more a gooseneck then my Reese hitch. Connecting the Andersen with a ball to the adapter changes nothing as far how the MorRyde functions, which is fore ,and aft movement . Is that not the same function of the Rotoflex, and if not, it still would not make any difference. I can see a problem with the gooseneck arm trying to flex back, and forth being extend down to the bed.
Unless I am missing something , that Andersen does not change anything other instead of sliding into a conventional hitch ,and connected ,its connected with a ball. As said its NOT a gooseneck, there is a lot of difference.
Check the Andersen website. A lockout kit is required when using an AUH with a RotoFlex pin box. The part number for the kit is 3247.
Andersen's own videos show the hitch being used with a MorRyde pin box.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
