DesertDogs
Dec 18, 2019Explorer
cummins2014 wrote:DesertDogs wrote:
So, the steel Andersen is a top choice with the RAM 3500 short bed? And, that's attached with rails to the factory pucks? No worries about clearance in very tight turns?
I’m pretty sure I went over this with you . I don’t know if it’s the top choice , it’s a good choice . Yes picture frame adapter attached to the pucks with the steel Andersen mounted to that. It’s the setup that I have , and I have no clearance issues in a tight turn . With that being said, there is a limit to how tight you can go , as with many setups.
c2014... what pinbox on your 5th wheel? And do you have the pin adaptor which is reversible to give more or less rear-ward placement on the hitch? Lastly, any clearance issues between the pinbox with the sides of the bed?
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
