Cummins12V98
Dec 19, 2019Explorer III
DesertDogs wrote:Cummins12V98 wrote:
DesertDog you have a great truck why do you want a complicated setup?
The ANDERSEN/adapter setup does NOT allow you to move the hitch back. I would NEVER mount the hitch so the pin is behind the center of the rear axle.
Get the puck mount B&W Slider and never have an issue.
Manual or auto slider?
Can I install and remove by myself?
No complications in use? (Operating the slider feature?)
I am sure Chris MeAgain can elaborate. The B&W does come apart for easier removal. I won't tell you a child can do it. But i will tell you you simply will NOT fine an easier to hitch under any condition or unhitch than any other non air ride hitch. the hitch will lock into the pucks that are directly attached to the truck frame unlike the rail mount ANDERSEN that is held in place with 4 small pins that will move around and make noise.
Post your question on the TDR and see what responses you will get.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
