Cummins12V98
Feb 18, 2017Explorer III
retispcsi wrote:
See truck and trailer in sig. A two inch riser is almost a standard option for DRV. It is easily done when you order your new unit. Assuming you have the Mor Ryde 8000 IS. I had mine done at Mor Ryde after market. I have 9 inch of clearance and the fiver is 13'5" at the highest point. It depends on the rig you choose.
Interesting, My 15 RAM Dually sits 55" to top of bed at tailgate at that area I have about 7" clearance. It took 3" risers to level my RV. The max height is 13' 5". Your truck rear suspension must compress to 53" ? Based on your numbers you did NOT need the risers. I am wondering where you took your dimensions.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
