moosepucky's avatar
moosepucky
Explorer II
Mar 02, 2026
Solved
Am I a Truck Camper?
Am I a small truck camper or should I be in.......
.......a class C or RV group?
Mick
  • That rig is a classic and looks in good shape.
  • Typical truck campers can separate the truck from the camper. Since yours is fixed, it really is a motor home. Your RV would be classified as a Class C motorhome since it has a truck or van cutaway cab on the front.
    • StirCrazy's avatar
      StirCrazy
      Moderator
      there are frame mounted truck campers which cannot be taken off, well they can but it is a big process and only going to be done in a shop.  what I always used as a decering factor was weather ou had to get out of the truck to go to the rv part, or weather you could just turn around, from the pictures I can't tell if you have access to the rv from the truck cab or not, but it sure looks like it could be aframe mounted truck camper.
  • Well that ain’t a truck camper, by definition, obviously.
    But looks like a cool classic little rig.
    who cares what “group” your in?
    • moosepucky's avatar
      moosepucky
      Explorer II
      Just looking for a campfire to set around and chat.
      Mike
