ford_coupe's avatar
ford_coupe
5th wheel battery replacement
Battery in my 08 durango finally bit the dust this year ,won't hold a charge. What do most of you use as a replacement brand? Thanks for any reples,John
  • There are very few battery manufacturers. They make all the different labels on a contract basis. Buy whatever you get the best deal on. It will most likely be made at the same place as the one down the street with a different name on the side.
    B.O.
  • I just took my old one to NAPA and told them I wanted at least an equivalent. Still works fine after 3 years.
  • Interstate worked OK for us. When it died, we replaced it with a Sears DieHard group 31 as we didn't have room for two batteries in the rig we had at the time and were going to spend time at Yellowstone in a campground with no electric. Worked well for us. If you do plan to stay at non-electric sites, you might want to consider two batteries, either 12 volt in parallel or 6 volt in series. Or, if like us with no room for a second battery, look for the largest capacity 12 volt you can find.
