spassyExplorerOct 12, 20155th wheel helpPlease any help will be appreciated! I have a Rockwood 8280WS with the reese revolution and a reese titan 20K hitch with the correct wedge. the problem is unhitching on uneven ground after leveling...Show More
Coach-manExplorerOct 12, 2015Put it in reverse, then neutral, that should free it up, if not you have a problem with that hitch!
Related Content5th Wheel took out rear windowAlliance 5th Wheels5th wheel tires5th wheel hitchesUpgrade to 5th wheel
