robby1824's avatar
robby1824
5th wheel hitch advice!!
Just bought our jayco 35.5 rets fifth wheel.....also purchased a ford F-250 SD 6.7 turbo diesel with the short bed....now we need the connection!! We bought trailer from camping world and they obviously have what they have....I have the tow package on the truck, MINUS the mounting bracket option....so I think I need
A. mounting rails
B. Sliding 16K+ hitch
Question is: Above or below rail mounting? I have seen that the manual slider is fine, and actually preferable...Is it smart to purchase all from camping world and let them install, or by on my own and have them install??....I paid extra for the fancier pivot pin on the trailer if that makes any difference. Pulling a trailer for years, new to 5th'ers!!
  • Traveler II is right on.No hitch out on the market compares to a air hitch.I have a Airsafe 25k since 2008 very happy with it,good quality great ride.
    The Hensley Trailersaver BD3 is a very good quality air hitch and Cost less than the Trailersaver and Airsafe.
    Do some research on both before buying a rigid hitch.
  • Rjdreyer wrote:
    I have a 16k pullrite superglide with super rails. I too have the SD short bed. So glad I spent the extra for the pullrite. Just hook up and go. Don't have to worry about anything unless I get to about 90 degrees coming or going. Camping World installed my hitch and rails.
    X2
    C.B.
  • Peg Leg wrote:
    The B&W Companion gets my vote. I did the install, only hole to drill was in bed for drop pin. I used a cheap hole saw with a oiled sponge inside. Had to make a notch under the bed where a heavy cross support went. My Companion and turnover ball was just over a grand total including shipping. All the bolts through my boxed frame had metal holder that you could insert the bolt through another hole and hold it while starting the nuts. With the teflon lube plate it still looks great after 2 yrs.
    This was my approach too. B& W makes a great product and has great support. No drill installation with the exception of that one big hole. Measure twice! If you do it yourself you know it is done right.
    IF you do it yourself, use a come-along and some type of homemade tripod (I used a stepladder and iron bar) to hold the unit in place and tighten it up against the bed before you tighten the bolts...this will make sense once you read the instructions. There are also you tube videos...
    I wouldn't let camping world install a light bulb for me.
    Same for us because our airhitch has been great since 2001.
    chevman
  • newman fulltimer wrote:
    If you have the Reese revotution pin box you do not need a slider hitch.in my opinion the best hitches are the b&whitches
    X-whatever on B&W. Love my Companion (and Turnover Ball) and the company is every bit as good as their products.
    Lyle
    HAH! That was my biggest fear about the DIY install of my Turnover Ball; drilling that 4" hole! When I helped my brother install his, I made =him= measure and drill his own hole. :-)
    Lyle
  • I have the same truck...gotta have the 16K Pull rite slider...also pull 4 pins and the bed is clear..quiet, no chucking and auto slide has saved me several times.
  • Really like my Hijacker. Yes its a manual slider (if I ever need it). But so far, after 7 years with this truck, have never had to use it. Much more reasonable in price than one of the auto sliders that you don't really need. Just MHO.
