I have a 2014 3500 megacab (6'4" bed) and am picking up our 2015 Fuzion 345 today. I also have the B&W RVK3600 hitch..I had them install a Sidewinder pinbox on the Fuzion as I did not want to risk hitting the cab in a tight turn...chose this combination because of B&W's reputation and I wanted to lock the hitch into the factory pucks. Thinking I should have maybe went with the fifth airborne sidewinder, but we will see how this does
If Superglide came out with a factory drop in for Ram (without using a PF), I likely would have went that way...it just seems that these new 4x4 trucks are so tall in the rear end that using the pic frame adapter and a superglide results in a nose high towing situation for most people...even with a pin heavy fifth...
